marbroman nouveau
Nombre de messages : 13 Age : 64 Localisation : Canada Date d'inscription : 09/03/2022
| Sujet: Ducellier Piece d'origine Jeu 7 Sep - 17:13:00 | |
| Hello all. I am trying to find a reliable source for Ducellier distributor parts for various Renault models. I completely rebuild Renault distributors for many models fitted with distributors made by Ducellier for Renault. What I really need is the catalogue of Ducellier part numbers for 1970's up to 1980. R241-4305 and other R241 D series distributors either with or without vacuum advance mechanism. Renault provided some internal parts for these distributors in the PR books for R12/15/17 but they only provide service kits such as points, condensers, some springs and clips, washers, etc. Many internal parts are available but only directly from Ducellier such as the shafts, cams, bushings, housings, etc.
Ducellier provided ALL parts from their own catalogues with their own part numbering system. Many of the internal pieces are completely interchangeable throughout a wide range of Ducellier distributors made for Renault, Citroen, Peugeot, Simca, etc.
I am especially looking for mechanical advance weights, springs, weight bushings (plastic), plastic rubbing blocks, etc.
Here are a few examples of Renault part numbers and their Ducellier part numbers
Mechanical advance weights: Renault p/n 7701021749- Ducellier p/n 18726 Service kit: Renault p/n 7701012451- Ducellier p/n ????? Service kit: Renault p/n ????????????- Ducellier p/n 611078
Note: most of the tiny pieces (c-clips, springs, plastic rubbing block, fibre washers, points retaining screws, etc.) are completely interchangeable across a wide range of Ducellier distributors.
Anyone that knows of a source please let me know.
Marbroman |
| Sujet: Re: Ducellier Piece d'origine Jeu 7 Sep - 19:10:33 | |
| - marbroman a écrit:
- Bonjour à tous. J'essaie de trouver une source fiable de pièces de distributeur Ducellier pour différents modèles de Renault. Je reconstruis entièrement les distributeurs Renault pour de nombreux modèles équipés de distributeurs fabriqués par Ducellier pour Renault. Ce dont j'ai vraiment besoin, c'est du catalogue des numéros de pièces Ducellier pour les années 1970 à 1980, R241-4305 et autres distributeurs de la série R241 D, avec ou sans mécanisme d'avance à dépression. Renault a fourni quelques pièces internes pour ces distributeurs dans PR pour R12/15/17 mais ils ne fournissent que des kits de remplacement, condensateurs, ressorts et clips, des rondelles, etc ... De nombreuses pièces internes sont disponibles, mais uniquement directement auprès de Ducellier, telles que les arbres, les cames, les bagues, les boîtiers, etc…
Ducellier fournissait TOUTES les pièces à partir de ses propres catalogues avec son propre système de numérotation des pièces. De nombreuses pièces internes sont totalement interchangeables dans une large gamme de distributeurs Ducellier fabriqués pour Renault, Citroën, Peugeot, Simca, etc… Je recherche en particulier des poids d'avance mécaniques, des ressorts, des coussinets de poids (en plastique), des blocs de frottement en plastique, etc…
Voici quelques exemples de numéros de pièces Renault et de leurs numéros de pièces Ducellier :
Masses d'avance mécaniques : Renault p/n 7701021749- Ducellier p/n 18726 Kit d'entretien : Renault p/n 7701012451- Ducellier p/n ????? Kit d'entretien : Renault p/n ????????????- Ducellier p/n 611078
Remarque : la plupart des petites pièces (clips, ressorts, bloc de frottement en plastique, rondelles en fibre, vis de maintien, etc...) sont totalement interchangeables sur une large gamme de distributeurs Ducellier.
Si quelqu'un connaît une source, qu'il me la communique. Marbroman _________________ R1312 '73 Blanc 355. |
