-17%
(Black Friday) Apple watch Apple SE GPS + Cellular 44mm (plusieurs ...
249 € 299 €
 Allumage Ducellier
3 participants
marbroman
Nombre de messages : 32
Allumage Ducellier Empty
MessageSujet: Allumage Ducellier   Allumage Ducellier EmptyJeu 22 Aoû 2024, 18:53
Can anyone in the R15/R17 community help me with my export model R-12 (wagon/break)- 1332 spec fitted with 1,647 cc 841-10 wedgehead motor (not the 843 semi). My ignition is a Ducellier R.241 WITHOUT vacuum advance. It is strictly mechanical advance and my internals need rebuilding.
I want to keep it ORIGINAL, so no electronic ignition for me.
I have sourced shaft bushings, new weights and springs but I cannot find the little white plastic bushings that the weights move the cam plate with. These wear out so fast. Older Ducellier distributors used steel bushings instead of plastic.
I have searched the internet for OEM Ducellier parts. I have tried R-12/16 Shop in Netherlands as Rero Velun and Vintage French Car Parts and no one has ANY internal Ducellier parts.
I don't have an exploded view diagram for my R.241 with Ducellier part numbers either.
Can anyone help me?!
marbroman
Nombre de messages : 50130
MessageSujet: Re: Allumage Ducellier   Allumage Ducellier EmptyVen 23 Aoû 2024, 11:33
Hello, Marbroman
please, shown us a picture from this ignition where we could see "R241Cxx" (xx is the curve) and his Ducellier reference.
May be, we will find on an other Renault with the 1647cc.
Michel
Nombre de messages : 9056
MessageSujet: Re: Allumage Ducellier   Allumage Ducellier EmptyVen 23 Aoû 2024, 11:51
Translate please.
MessageSujet: Re: Allumage Ducellier   Allumage Ducellier EmptyVen 23 Aoû 2024, 12:01
Je suis champion en langues étrangères avec cela " https://translate.google.com/?hl=fr&sl=auto&tl=fr&op=translate "
Quelqu'un de la communauté R15/R17 peut-il m'aider avec mon modèle d'exportation R-12 (wagon/break) - spécification 1332 équipée d'un moteur wedgehead 841-10 de 1 647 cm3 (pas le semi-remorque 843). Mon allumage est un Ducellier R.241 SANS avance à dépression. Il s'agit d'une avance strictement mécanique et mes pièces internes doivent être reconstruites.
Je veux le garder ORIGINAL, donc pas d'allumage électronique pour moi.
J'ai acheté des bagues d'arbre, de nouveaux poids et ressorts, mais je ne trouve pas les petites bagues en plastique blanc avec lesquelles les poids déplacent la plaque à cames. Elles s'usent très vite. Les anciens distributeurs Ducellier utilisaient des bagues en acier au lieu de plastique.
J'ai cherché sur Internet des pièces OEM Ducellier. J'ai essayé les magasins R-12/16 aux Pays-Bas comme Rero Velun et Vintage French Car Parts et personne n'a de pièces internes Ducellier.
Je n'ai pas non plus de schéma en vue éclatée pour mon R.241 avec les références Ducellier.
Quelqu'un peut-il m'aider ?!
marbroman
Bonjour, Marbroman
s'il te plaît, montre-nous une photo de cet allumage où nous pourrons voir "R241Cxx" (xx est la courbe) et sa référence Ducellier.
Peut-être qu'on le trouveras sur une autre Renault avec le 1647cc.
Michel
MessageSujet: Re: Allumage Ducellier   Allumage Ducellier EmptySam 24 Aoû 2024, 17:44
Allumage Ducellier
» allumeur ducellier
» Allumage
» allumage.
» Affectations des Allumeurs Ducellier.
» allumage
